1 - 3 of 3 Posts
· Registered
I'm trying to get parts info and correct terminology for descibing my problem. I've developed a fluid leak from the small circular area above the fluid pan on the passenger-side of my automatic transmission. I've been told this is 'servo' plate cover composed of a molded rubber gasket. Is the gasket itself replaceable? Is there more to it than that? Someone else told me there is an O-ring here that needs replacing? I've tried finding a detailed parts diagram for this location and have been unsuccessful. Anybody know what I'm dealing with here? What replacement part / parts do I need to consider ? How might I describe this condition accurately to a mechanic? This is not something I would fix myself, I'm just trying to gather enough info to avoid being taken to the cleaners on repair costs. Please help. ( 1999 Isuzu trooper automatic transmission)
· Registered
norgil99, (I'm not trying to be insulting!!).. but are you sure it's not the fill / ATF level check plug leaking? The drain & fill plugs on these pans are known leakers if the rubber gasket is not replaced, they almost always tear after a few years when the plugs are removed/tightened for ATF service. I guess they have a "newly designed" plug now to eliminate this. G/luck
Joel
1 - 3 of 3 Posts
