In case I park the truck until I get springs I am thinking about digging into an oil leak that has been bugging me. I have oil coming out of seals about half way down the aluminum block. It runs onto the exhaust maifold and stinks the place up and also ends up all over the inside of the frame rails. I don't know this engine well but am hoping it is the valve cover gaskets (may be cylinder head gasket).
The engine runs pretty well but my driveway is a fright and it looks like a refinery exploded under the truck.
I am pretty sure I can muddle through the valve cover gasket but not to sure about going much deeper.
Assuming I only go as deep as the valve cover gaskets will I need any parts/special tools besides the below:
BECK/ARNLEY Part # 0376009
Manifold Set, Intake, Contains Plenum Chamber Gasket;1 Per Car
BECK/ARNLEY Part # 0361602
Valve Cover Set, Contains Spark Plug Tube Seals;1 Per Car
Any advice from those who may have done this before?
I would also be interested to hear from anyone who has replaced the cylinder head gasket(s) on this engine as to what is involved outside of removal and reverse installation. I am assuming I will have issues with orientation of valves/lifters and such which is probably over my head a bit.
I have Alldata and a Haynes manual for reference but in my experience they are not always very accurate and I do not want to get in a position that I cannot but the motor back together or worse I put it back together improperly and damage it.
Some of you guys really know your stuff so that is why i post here :wink:
Nathan
Nathan
