ALL 2.3 AND 2.6 ENG SHOULD HAVE THE 8 BOLT FLY WHEEL SAME PATTERN AS THE 3.2 V6 , HAVE INSTALLED THE 2.3 FLY WHEEL ON THE 2.6 MANY TIMES WHEN SWAPPING IN A 2.6 INTO WHERE A 2.3 WAS, FLYWHEELS BOLT RIGHT ON, EVEN THE 2.0 IMPULSE TURBO 4ZC MOTOR USES 8 FLYWHEEL BOLTS . THE G200 AND THE 1.9 ALL USED 6 BOLTS.lowzone said:sorry, i meant the 2.3L and 2.0L should share the same 6 bolt...not 8 bolt like the 2.6L. my bad....i looked at a 2.6L washer plate and the 2.6L IS 8 bolt.
YES ALL THE 4Z SERIES ENS WERE 8 BOLTlowzone said:oooooooooooooooooooooooooooo Jerry, thats very interesting.
so this flywheel is for the G180 G200 motors....
mental note on the 2.3L being 8 bolt, making the 4ZC1 2.0L impulse motor an 8 bolt also
