1 - 17 of 17 Posts
i think the best way to find out is measure the fin thickness , 2 row will be about 1.3 inches thick , 3 row will be about 2 in thick.
I'll have to go out and measure. This truck, being a 2.6 1st gen Trooper with a manual transmission, should have had a single row radiator. I checked it out today and it looks like it is a 2 row. I was going to order a 2 row radiator, but I might not have to now!
The fins measure about 1 3/8", so that makes it a 2 row then?
thats a 3 core, unless it has more rows that can not be seen.
theres very few Isuzu's with a 3 core in the older autos, i don't have a clue as to if any newer isuzu's came with a 3 core?
or did it come out of something else :?:
It came out of my 88 Trooper.
It does not have the trans cooler lines at the bottom, so I'm guessing it has been re-cored at some point.
Either way, can I be certain that this is not a single row radiator? If it is not a single row, I'm gonna put it back in (I was going to order a new 2 row rad).
Thanks!
thats a 3 core, if its in a 88 trop its not ORIGINAL
they had 1 and two core only.
you see the narrow slots and there three high :?: if that was one row of narrow slots "left to right" it would be a one core. if there was two in there it would be a two core.
I tried to get a nice close shot of the inside of the rad, maybe I got too close though. Here is another one:
So, looking at this one, there are 2 rows stacked front to back, making it a 2 row right?
David, I don't know how you know what's left to right in that photo. It looks to me more like:
than:
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Jadk
All the Zus up to 97 with the 2.6 5 spd manual had dual core. All the Zus with automatics and 6 bangers had 3 cores. Its next door to impossible to get a new 2 core these days. All the replacement rads are coming as 3 cores with tranny coolers....
They work just fine in a 2.6 5 spd. I have one in mine that replaced the original 2 core. Only problem with the replacements is you can not get one with metal tanks. They are all plastic.
than:
Jadk
That's why I added the less close-up picture. Sorry about that. It is like this:
Front
Back
I thought for sure that the early troopers had a single core unless they were the auto trans.
JLEMOND said:
GET THE RADIATOR FROM ANY 88-91 TROOPER WITH THE AUTOMATIC TRANS IT IS A DUAL ROW RAD, AND IF EVERYTHING IS OK WITH THE ENG IT WONT RUN HOT , MAKE CERTAIN THE CLUTCH FOR THE FAN IS WORKING, THESE THING DO WEAR OUT SO SLOW THAT YOU NEVER NOTIC E THEM , JERRY
I got that from:
http://forum.planetisuzoo.com/viewtopic.php?t=10562
yea :oops: sorry the photo was too close, its a two core
Off topic, but you can tell somebody's a Unix/Linux nerd when they find an excuse to use the pipe ("|") character. :lol:
The rest of you won't get it. Sorry.
Jack
Jack
ps -ef | grep JoeIsuzu
1 - 17 of 17 Posts
