1 - 7 of 7 Posts
· Registered
SOLD
Forsale. for 92+ Troopers
I got Matt's 2-3" kit but did not lift it that tall so I'm looking to go with OMEs shocks now.
Sell RS9k Front and Rear. Fronts are installed and have about 3k on them now. Rear is still in the box and are the extended ones for better flex. The Ball joint spacers and rear brake line extension is still in the box as well. The Rear shocks are the longer ones so you can get coil spacers to go to 3" lift.
All was about $380 from Matt, but willing to take $150 for all plus shipping.
PM me if you have any questions or offers. Thanks.
Cheers,
Con
· Registered
Shocks do not lift your truck. OME or anyone else! (unless using coilovers) Adjustable shocks control rebound and damping-Not Height.
· Registered
I'm pretty sure he was referring to the fact that his lift didn't take him to a height that required the length of shocks that he got. He's got a bit of time on the pond. Easy does it.
Later...
· Registered
Later...
You are part correct. Indy's 4x "kit"(aka means more than just shocks) can be lifted in stages. So I only lifted the Trooper to 1.5-2"(using only the shocks, 1.5-2" longer OME coils and a t-bar crank in front). And I did not use the rest of the kit which can go up to 3"(which would have been the ball joint spacers, coil spring spacers, longer brakeline brackets, etc). Indy's lift kit specs longer shocks so you can really get 3" if you want(as the normal Rancho spec'd shocks are too short to flex for a 3" lift). Yes the shocks don't lift the truck, but the coil spring spacers do on top of the taller than stock OME coils that comes with the kit which I did not use the coil spring spacers so it only lifted 1.5-2" or so.
Maybe my original post was confusing so I'll re-write it now: "I got Matt's 2-3" kit but I did not lift it that tall(as the kit can lift in stages) so I'm looking to go with OMEs shocks now"
Toddz, is that better? ;)
Plus farther down the post I stated this: "The Rear shocks are the longer ones so you can get coil spacers to go to 3" lift." So hmmm...... I did not state the shocks lift the truck after all......... ;)
Cheers,
Con
· Registered
Sorry Guys-
Sounded to me like Conman thought that his Indy kit with different "adjustable" shox would "lift" his truck higher. Mizundastood I guess...? No stress-
TZ
· Registered
dc_trooper said:
are these still avaliable?
Still are. PM if you have any questions.
Thanks,
Con
1 - 7 of 7 Posts
