Starchild said:
I'm not sure if you will have to break loose the upper ball joint to be able to get the old one out or not.
Nahhhh... Oftentimes you can reach right in there without too much trouble.
But if you
can’t get to it, then you might have to use a jack on the Lower A-arm
(or go find a spot that compresses the front suspension a bit â€" forcing some up-travel)...
Once you achieve the necessary clearance - simply feel around on the under-side of the Upper A-arm for the stock bump stop… Then, on the top side of the Upper A-arm, you'll see a small cylindrical piece of soft black rubber sticking up that matches its position...
That stem is what you cut off - making sure that you cut below the retaining nub, right up against the surface of the A-arm. --- The old bump stop should fall right out.
Then, on the bottom side of the Upper A-arm, mount the new one from Matt into the same hole that just held the old one.
Switch sides and repeat.
Cheers!
Smiley
