1 - 10 of 10 Posts
is it possible to install a cb in the dash below the ashtray, to the left of the power outlet and behind the shifter? there is an indentation little cubby type hole there and it provides a rather convenient flat spot.
has anyone taken the dash piece off there? is there anything behind it to prevent a cb from going in?
the one i just bought measures perfectly, i just don't know about the depth.
no, i can't mount it under the stereo cause i have an aftermarket cd player and the available cubby hole is tiny.
i mean below the ashtray. (that website did provide the pic i was after though!)
There's not a whole lot of room behind that panel for a CB. You'll have just a few inches, at most. I'm speaking from my experience with my Trooper, which has a similar arangement.
You may be able to reroute some stuff, but you'd have to remove the panel to see for yourself just how much.
yeah, i saw that today. i am going to try for the ashtray. the cb i bought is a little thing, so i hope it will fit.
i'll see soon!
Premium Member
Bruce (old time Planetisuzoo member) installed his in the lower DIN slot:
http://myweb.cableone.net/bcanderson/trooper/cb/cb.html
I installed mine there too:
I used the left factory bracket and cut a piece of plastic to fill the gap. Then I glued the plastic to the CB. The right side of the CB floats. It doesn't move around much.
I also installed an external speaker:
I'd install that Radio Shack speaker again in a heart-beat. It is very loud and quite clear.
-Tad
also, i want to run the PA. (only for the novelty...i can't see a purpose for having a PA unless you're a cop...but i think they're fun!)
any reccomemations on speakers or installations? anyone done this?
Premium Member
I've run a PA in the past. It was fun at the drive through yelling at them as they yelled at me. I used a Radio Shack outdoor speaker for the PA mounted behind the bumper.
I'm not sure if this would fit where your ashtray is. My ashtray is a bit different. Can you measure the width of the hole for your ashtray?
-Tad
i think this is gonna work out great...
the cb i bought is the Uniden pro 520. the dimensions of the unit are
4 1/2" wide, 6 1/2" deep and 1 3/8" tall.
the actual available opening for the ashtray is 4 5/8" wide (the ashtray is a bit smaller, so i have to trim), the depth available seems like forever at the top and the height available is something like 3"
as far as i can tell, i remove the ashtray unit completely make some sort of mounting bracket and pop the cb in! i also need to fab some sort of cover for below the cb where the ashtray would sit.
i will also no doubt need to hook up an external speaker so i can hear
i think its gonna look good.
i'll post some pics when i get it in.
1 - 10 of 10 Posts
