I have a few questions about the brakes on my 94 Trooper.
1. There are 2 distinct types of caliper pins on each caliper. One is normal looking, the other has a funny bottom. I cleaned one of the pin holes out and found what appeared to be some sort of deteriorated rubber sleeve in the hole -- is there something that goes on this funny looking caliper pin???? If something is supposed to be attached to it, will I be ok not using it? Advance Auto parts looked up the part and found no illustration of anything on the funny pin -- but they're not exactly the world's authority on this either!
2. I'm having all my rotors resurfaced -- the rear brake pads needed replaced (metal on metal), but the front pads look nearly brand new. The problem is: there were some grooves in the front rotors (which is why I'm having them resurfaced) -- do I have to replace the brake pads as well? Obviously the brake material is softer than the rotors -- but are they capable of scoring the rotors if they have slight groove marks in them? They look to be ok pads, but I don't want to damage my new resurface job. Professional opions would be greatly appreciated!!!!
3. Is it ok to use high temp moly/lithium based grease on the caliper pins or is there something else that should be used???
Thanks in advance for any help on this project. At least if I do it right I won't have to mess with it for another 40k miles!
Michael
Michael
