front hubs...
Ok... skip ahead to where the hub is laying on the floor on a towel.
I pulled out the wheel seal with a claw hammer rather than using the special "tool," seemed to work fine.
Pulled the bearings out, layed them aside... This is the point, where I think most folks bring the hub to a shop to have it put on a machine to press the bearing races out... and press new ones in.. My problem, is I'm a cheap guy who will try to do anything at home to save some money when I think it's possible..
Is it ok to have done the following..
1. used a punch (ok actually it was a different set of random tools that I didn't mind banging on with a hammer), and changed back and forth from side to side where the inner side of the race "lip" is exposed and "beat them out." If I had to do it again, I would have bought a brass punch- I did end up slightly scaring the inside of the hub. (oops)
2. Took the old races, and ground them down with the grinding wheel to be smaller diameter, and used them on top of the new races, to press them in, with a block of wood and hammer. (ground down the old ones so they wouldn't get pressed in at the same time).. Is this method ok? (I hope so, cause I already did it, lol)... I made sure the new races were pressed all the way to the lip inside the hub...
4. Didn't buy a bearing greaser tool, I just filled my hands with huge gobs of grease and squeezed as much into the bearings as I could by hand...
5. Used block of wood + hammer method to get the new wheel seals in.. However, one of them bent instead of going in... (get to go buy a new one tomaro to do the other side with)... So, all I can say on that is, darn dang shoot, it's finiki to get that wheel seal to line up and go in straight...
Now it's question time.... I'm putting the hub nut back on. I understand i'm supposed to tighten it, turn the wheel a few times, whipe up excess grease as it spews out, then loosen it, then retighten it... repeating this several times.. Problem I have is how tight to tighten the hub nut.. I don't have the "tool" for the nut.. I used the haynes manual method- which involved putting a punch into one of the holes sideways, and beating on it to loosen it, which worked great, but how on earth to tighten it to the proper torque.. Think I might go buy the proper tool or make one out of the ford hub tool, then using a torque wrench- I think I read it's supposed to be tightened to 5-8lbs (sound right?)
