1 - 12 of 12 Posts
I have a 91 rodeo, and the speedometer says im going about 15mph faster than i really am and wen i get to around 50mph (the speedometer is at 70mph) its at 3,000 rpms which is high to be steady holding it there!!! i changed the clutch and it didnt help... culd it be the rear end, or what??? ive also heard maybe the tranny but i dont know!!!
what are the tire size?
What size tires? I assume you checked your mph against another vehicle or maybe GPS? My 91 Trooper with 3.1 and 5 speed runs around 2500-2600 rpm at 55 if I remember correctly. I'd not be concerned holding mine at 3000 rpm though. Maybe I'll look at my rpm vs. speed a little closer next time out.
sorry, i lost my log in info... i had 285 65 16 on it but went back to stock tires cuz i thought it was the problem but it wasnt... i also changed the clutch but the didnt help either... it wuldnt bother me except for i drive it every day and im at a steady 3000 rpms for like 30 minutes to and from work... the only other thing i can think is rear end or tranny but i dont know... i mite just trade for a trooper or a 4runner cuz i need a cruiser
At 70 MPH my Trooper is over 3k rpm. Pretty normal actually. I have big tires but with the 4.77 gears it's pretty much the same as stock.
On mine at 3000 RPM It is cruising right about 75. It has 235/15 tires and 4:56 gears. Auto trans
Nothing wrong with your clutch, transmission or differential (rear end). You just have a speedo gear/final drive ratio/tire size mismatch. If you get the right size tires on it (bigger than you have now), your speedometer will read accurately.
I'm actually a little puzzled that the tires you had on it weren't right. They're what amounts to a 31" tire, which is about factory size for these things, or so I thought. What size tires to you have on it NOW?? That's something we need to know before someone can figure out what the problem is.
One last possibility: Did you buy it from someone who might've changed the gears in it for something lower (higher in numbers) to support oversize tires? Your speedometer is reading 40% low, which is a huge amount, considering it would take something like a 42" tire to "fix" the problem, if you still have the 285/65's on it and your speedo is still that far off. Someone please tell me my math is off, here...
How do you know it's off?
depending on gear ratio your 5spd could be running at 3000 rpm at 70 with smaller tires
You need to find or borrow a GPS unit that has the ability to read MPH and check it that way. Most do. I mean I hate to bring it up but is it shifting into high gear if auto or if a stick are you getting it into 5th? I know dumb question but I had to ask.
I've asked a highway patrol to check my speed a couple of times when I wasn't sure my speedo was telling the truth. The first time, the guy was cool with it and let me make about 4 runs past him at different speeds, calling my speed out on the CB on each pass. The last time he was a little pissy about it, but did it anyway when I asked if I should find another trooper and ask him instead, but in his defense, he'd been bitten by my dog a few months earlier during a "spot check" when he smiled (baring his teeth, which to any young dog is a show of aggression) and reached in the door to try and pet her.
:D Please :D don't :D show :D this :D post :D to :D your :D dog. :D
1 - 12 of 12 Posts
