Hi,
I live overseas (Central America) where there is no federal regulation such as the one in the states. I am going to the mechanic tomorrow to have the catalytic removed at his recommendation (Cat is not available at local parts stores). HE suspects the my cat is clogged as 97 Rodeo 3.2 V6 is experiencing hesitation upon acceleration and very sluggish and hesitant on hills.
My question is, what will happen to the O2 sensor or sensors? How many are on a 97 3.2 V6? IS he going to bypass them?
Reason I ask is because he also mentioned that my O2 sensor is bad. He connected an Actron OBII scanner and advised that the sensor is bad.
I was going to replace the O2 sensor but since we are going to remove the cat, I don't know what will work best.
Also, my exhaust has a STRONG gasoline smell like gas is not being burned and my fuel economy is really bad.
Will O2 sensors be needed if we remove the cat? I am hoping that I run leaner rather then rich as I suspect due to bad O2.
All in all, what I want to accomplish are:
1. Fix hesitation upon acceleration,
2. Improve gas mileage,
3. Stop strong gas smell from tailpipe (possible rich mix due to bad O2)
I want to go the economic route before going crazy spending money in other parts. If hesitation and gasoline smell do not stop, I then will replace plugs with NGK's and possibly the fuel filter.
