1 - 8 of 8 Posts
markbrickens said:
Can I use a Honda Passport part instead? They are $338 in Indianapolis
what part number exactly do you need? i MAY have it in my inventory but "actuator" is too general of a part. transmission related? engine? shift on the fly front drive? just need more info, we may be able to help you with lower priced OEM NEW or used...
Ron
This one was dropped somewhere in 2003 or 2004. My vehicle does not have one - both half-axles are permanently connected. The 2WD/4WD connection is performed only in TC.
I actually like the late-years design - no front "hubs" and no actuators. It is stronger and simpler.
I'm pretty sure they still have an axle disconnect in there.
Going through my vehicle hardware, and through the myisuzuparts.com, I figured that they dropped that somewhere in 2003. I had a 2002 Rodeo, and I know the difference.
holger said:
Going through my vehicle hardware, and through the isuzuparts.com, I figured that they dropped that somewhere in 2003. I had a 2002 Rodeo, and I know the difference.
regardless, its still a vague part request. i have shifter actuators for the trans somewhere here , but the 03-04 had the Aisin trans, correct? not the GM car trans..either way i need a part number or picture to see if i have what they need and for a **** load cheaper then 340.00
of course, the request was vague, I agree.
I'd be curious to know more about them if they don't have an axle disconnect.
1 - 8 of 8 Posts
