Hey guys, I'm installing the Aisin hubs and I'm stuck.
I've got the hub body on and it's RTVed. I then installed the original shim (.012") and then the original snap ring. However, there seems to be way too much play between the snapring groove and the shim.
Did I install something incorrectly? What do I need to do to fix this? (I removed the snapring to take the pic)
As for installing a thicker shim, is a gap of .075" suppose to be closed with a shim?
