First pull the engine out. Remove the pan and clean the sealing surfaces of the pan and block. Pull the rear main cap and clean where the cap and block make contact. Use Permatex brand ULTRA BLACK RTV and apply a small amount on each side of the cap where it contacts the block and reinstall and torque to specs. Apply a thin coat of RTV to the block where the pan contacts it and bolt the pan to the block. It uses no gasket. The only gasket is between the upper and lower pans.
