1 - 3 of 3 Posts
'92 Trooper 3.2L SOHC | 5spd. Speedo dead, replaced VSS = no change.
I found this VSS / Speedo Test & want to find out from the gurus if this is accurate. The VSS test is indeed accurate, I tested mine & got voltage spikes (4 per rotation). In this article it gives Ohm resistance values between the 4 screws/contacts for the speedometer, yet my FSM says "solid-state do not test resistance".
Who can confirm deny this method of testing a speedo, or provide an alternate?
(Orig thread)
~psguardian
1 - 3 of 3 Posts
