homemade trans jack
334 Views 4 Replies 3 Participants Last post by  Shawn Anthony
Reactions: 1
I made a similar contraption when I was a teenager. It worked pretty good for the many years I used it. Assuming that your garage floor is almost parallel with the engines crankshaft, this contraption you made should work just as well. Nice work!
Reactions: 1
that's sweet, you love to see it
Reactions: 1
I shimmed up the front to match the engine angle
Problem solved.
The first one I made was all welded together. I didn't think of angles being a problem then..well I learned the hard way. I ended up shimming the jack stands the vehicle was on to match the homemade Jack.
Reactions: 1
