Hello! I have a 2002 Isuzu Rodeo Sport V6 4WD. 186k Miles.
I bought this car in February and have only been able to put on about 50 miles since. In the 50 miles I got a fresh tank of gas, oil change, all new fluids, and a new battery.
It stopped running in early March and I didn't have much time to mess with it until a few weeks ago in June.
I replaced the fuel pump, and it ran for a day after that. Drove about 15 miles, then it stopped running again.
I got codes P1290, P0463, P0135, P0155, P0452, and P0134.
With that, I cleaned the throttle, EGR, and the tube that connects the two. It was completely clogged with gunk, but it's now cleared out.
After that, it still wouldn't start, but those codes cleared and I got a set of new codes:
P1125, P1295, P1120, and P1220.
With that I replaced the throttle position sensor, and now I'm down to:
P1125, P1295, and P1515.
I know P1125 and P1295 are a result of P1515.
Since I've had P1515 I've cleaned and tightened the grounds, and I've just cleaned the MAF Sensor.
Now I have P1516, and am at a loss. I can get the car started for about 30 seconds using starting fluid, it'll rev up to 4000rpm a few times, then go into reduced power. I bounce around at 200-400rpms and slowly die out.
Does anyone have any other ideas of what I can try??
Thank you in advance...
