Okay, so here's the issue:
My passenger front wheel and tire have a wobble top to bottom as I'm driving down the road. I causes jerking to the right. Sometimes when I stop and check it the wheel is sitting true and other times the top is angled out. looking at the trooper from the front it would look like this
and at other points in the like this
I don't think the wheel is bent and when I jacked it up, there was less than a half inch of play in and out when pushing/pulling top and bottom. no play from front to back.
What to do?
Also, I noticed, when I was underneath that the CV boot is cracked...doubt it has any direct corralation as I remember it being cracked a few weeks prior to this happening...also, the issue must have matured over the course of a few days because I can't remember it actually starting this issue, just that I began to realize it was there and getting worse.
ball joint? tie rod? something else I can't think of?
Thanks for any help you can give guys (and gals),
Brian
What to do?
Brian
