I'm not sure how low you want to go, but by backing off the height adjusting bolts, which unload the torsion bars, you should be able to get it fairly low. The bolts are located on each side of your truck, out toward your rocker panels, approximately under where the front seats are. Just be sure to back each side off equally or you'll have one side lower (or higher) than the other. Also, whenever messing around with the IFS (independant front suspension) I strongly suggest having yor front end aligned, or at least inspected for proper camber, caster etc. Hope this helps-
