1 - 3 of 3 Posts
Well my blower motor stopped working. I'm pretty sure it is because of the leak that is right above it. I took the motor off and water poured out. I havent tested it yet but I am going too soon. I searched around here and found info on location of fuses for it. I checked the one under the hood and it is fine. There is also the resistor there but I dont know how to tell if that is good or not. Is there another fuse under the dash near the motor? I have a 95 rodeo.
well the easiest way to check that the motor is good is take it out and jump it to the battery .
Or run some wires from the battery to the blower motor and jump it .
If it works then the motor is good and youll need to follow the wiring schematics back from the motor.
1 - 3 of 3 Posts
