Hello, I am new to this board and needed help finding part numbers for several piece of the fuel pump assembly.
Mainly:
-The in-tank filters
-and the hose that connects the pump to the outlet(the corrugated, flexy tube)
I nicked that line while replacing the vapor pressure sensor. I was going to replace it with 5/16 diameter vinyl hose rated to 55psi working pressure in the mean time.
It seems like there should be a replacement the does NOT require me to replace the entire pump assembly.
Thanks for your help.
Mainly:
