Joe's right - there's really nothing difficult about swapping the transmission mount. --- But after reading this line...
R3 said:
I have excessive movement from the engine/transmission and figured its time to replace this.
...and noting that you included the ENGINE - I hope I’m wrong, but - I'm wondering if the transmission mount is really the problem.
I was having the same trouble with mine, and just like you, I reasoned that it was probably the transmission mount… so Rubo and I replaced it in Uwharrie with one that Joe Darlington brought me â€" but it didn’t make a bit of difference… in fact, the one that we took out looked perfectly fine - And the movement I was experiencing didn’t go away either.
So, a few weeks ago I had a local shop replace my engine mounts (it’s a much harder job - one there is
NO WAY that
*I* would attempt doing myself!)… The old driver’s side mount showed signs of contact between the ‘buffer’ and the outer-most support wall â€" which seemed to indicate a misalignment of some sort. --- Anyway, afterward, with the new ones in-place, every time I’ve cold-started the engine, it has still clattered just like before.
This may only apply to mine, but it’s starting to look like maybe I bent the frame last April when I whacked that big rock… this would certainly account for the evidence on the driver’s side mount that the engine might be sitting a wee-bit over to one side.
Anyhow â€" I’ve written all of this as a foundation for this question:
Have you thumped yours very hard on anything lately?
If not, then replacing the transmission mount (and/or perhaps the engine mounts too) might just take care of it. --- But if you have, then this might be a bigger problem than you originally thought.
I’ll keep my fingers crossed for you that it’s just one of the mounts. --- I’m
SOOOOOOOO not looking forward to tracking it down on mine.
Cheers!
Smiley
