1 - 4 of 4 Posts
There are three bolts along the firewall...the middle one and the one by the brake booster often get missed.
Did you remove the engine lift bracket?
When I did mine I had to remove that to make it easier. I just ended up leaving it off and putting it aside.
i have seen post on the planet about this problem and it always seams to be a bolt that someone forgot to remove and then BREAK....they break the valve cover so check to make sure you have ALL the bolts out.
1 - 4 of 4 Posts
