1 - 3 of 3 Posts
I'm attempting to put on old man emu coils, well we used spring compressors and got the stock ones out but now we cant get the ome ones in. so we were going to disconnect the arm that goes above the gas tank, but now we cant get the lower trailing arm bolt holes to line up to put the bolt back in. any suggestions?
It's not worth using a spring compressor. If you have trouble getting the upper link to lin back up all you need to do is use a bottle jack and if you have a hitch put the bottle jack between the hitch and the bracket for the upper link, it will rotate it right around.
Glad you got yours up where it belongs.
Joe
1 - 3 of 3 Posts
