I am installing PIAA 520 driving lights in my 98 Troop. Almost everything went in without any issues and looks great, except Inow need to power-up the relay and install the switch.
Basically, I need to tap/splice into the high-beam power wire, and then run the on/off switch through the firewall and into the interior and mount it on the dash. I need your help.
Which wire is the power wire for the high beams? How should I route the switch wire through the firewall?
Thanks a lot.
Thanks a lot.
