Hello I am having issues with removal off crankshaft pully bolt. I have a 1990 Trooper 2.6L and need to remove lower timing cover to change water pump. I am seeking advice on how to keep the flywheel from turning through the starter? I have snapped two 6/40 bolts trying a temp 1"x1/4 bar off the pully hub letting it brace off the front stabilizer while turning the 24mm bolt with a breaker bar. The manual says something about starter removal and flywheel tool?
Frustrated and out of penitrating oil! Help Please....Neoman :twisted:
