Looks like a solid truck! Welcome!
Thank you!Looks like a solid truck! Welcome!
Thanks and great to be here.That engine bay is spotless. The combo of no smog pump + carb makes it very minimal. Looks solid. Welcome to the planet!
Really clean looking truck. These engines don't respond to over heating well so one recommendation I might mention. A lot of these trucks without air came with a single row radiator. If yours has one a good upgrade would be a dual row one. The 16 in wheels are a nice upgrade. Isuzu made some 16x7 alloys we nick named snowflakes that would look really good on yours. Can't see if you have a shroud on your radiator or if you have the bigger fan but those help also
with cooling.
Thank you for the tip! I just got the standard one row replacement. The old fan shroud wouldn't fit with the new radiator so I left it off (for now). I still have the shroud. Yes the snowflakes are really the better look I think. The local OfferUp is pretty dry on anything Isuzu but has Toyota everything. Have two sets of the steelies they were cheap. $120 total for 8 rims. One set for daily, one for snow tires.Really clean looking truck. These engines don't respond to over heating well so one recommendation I might mention. A lot of these trucks without air came with a single row radiator. If yours has one a good upgrade would be a dual row one. The 16 in wheels are a nice upgrade. Isuzu made some 16x7 alloys we nick named snowflakes that would look really good on yours. Can't see if you have a shroud on your radiator or if you have the bigger fan but those help also
with cooling.
Thanks Ron. I had no idea what that rail was for and didn't research so I left it. That's my next project 👍. Great advice and good heads up for parts. Appreciated.nice ride!!! One thing you could do, as it seems you like your engine bay clean, is to remove the air injection tube and put in brass plugs. Its a standard thread, i think its 12x1.25mm, same as a spark plug thread. gets rid of that rail and cap you have. Some people have the threaded part welded shut but it can cause a chirping sound as the bottoms are still hollow. always likes the 88-95 style, best trucks ever in that generation. enjoy it!!! on a side note, i part out 88-95 pickups so if you need anything, i might have it.
Ron
