I am pulling a camping trailler with my 98 3,2 4x$ Auto.
One of my coil spring has snap in the first turn (at the base, 5 inches after the beginning). I assume the weight of my trailler to be at around 4000~4500 Lbs. (witch is dead on the limit, i know...).
I found out that OME has an heavy duty spring that mkes a lift of 2.5 inches. I don`t mind having a 1" lift but 2.5 inches sounds a little too much to me.
With OME my choices are
912 2" Soft
913 1" soft
919 2-2.5" med-soft
929 2-2.5 firm (also known as heavy duty)
Would a soft OME already be stronger than the OEM ones (I Don`t really want break a new ome coil after 1 season) (Are they much bigger in diameter than stock (wire size))
If I am to go 2-2,5 inches I will probably want to go with the 929, since I will have to face all the expenses of a 2.5 inches lift (Torsion crank,Lockers, allignment)
Is there any other company that does coil springs for the rodeo that could
give me a heavy duty load without the lift.
Anybody has the 929, How bad is the handling with them?
Is it only me or those OEM OME names are a little confusing? they should have pick MOE or EOM or EVH...
912 2" Soft
913 1" soft
919 2-2.5" med-soft
