I was under the Trooper looking at the new OMEs shocks and coils and noticed the rear drive shaft had a few grease fittings. They did look pretty dry so I was wondering what kind of grease did you use? I think my Chevy uses EP2 Grease and was wondering if this is good for the Trooper? Also, what brand of grease/model did you use?
Also, what else should be greased up? How and where are all the grease fittings.
Reason I'm asking is that I found out there are 11 grease fittings on my pickup and some of them are hard to get to so I'm sure the dealer does not hit them all so I figure I better do them on my Trooper as well.
Thanks,
Con
Thanks,
Con
