ok, I read the article with instructions to move the upper ball joint to below the upper arm to correct issues with alignment after cranking torsion bars. also provides a little extra drop down...
here are some things that went wrong....
when banging on the spindal, it dropped down, and I think it might have busted the C-clip holding the shaft into the hub, the hub assembly popped out at a funky angle and pretty much all of the pressure of the drop was suspended by the tie-rod and brake line.
so, that made for an interesting menuever to get it back up into place, holding it up to suspend stress off the brake line, while taking the caliper off to get it out of the way was an interesting chore. then I was able to jack up the lower A-arm and align the newly positioned bushing back into place...
OK, here's the BIGGEST problem.... I'm in the proccess of trying to tightent the castle nut back up. rather than turn over the threads, it's turning the bolt inside the ball joint very freely. I have no way of tightening this up because I can't find any way to "stop" the other side of the bolt in the ball joint.
do I need to get new ball joints?
Does half shaft normally just slide out of the hub if pulled on? or did my c-clip break?
if my C-clip did break, no sweat, I was plannin on putting new hubs on tomaro anyways. but jeeez.
this is turning into a nightmare, haven't even touched the other side yet- as it looks now, I might also have to replace the brake line.
going to go monkey with it some more then prolly go to sleep. any help in this matter would be so very apreciated.
