I'm curious what options I have for gearing, I have foud that I am towing regularly and already have oversized tires, and would like to go with 35's in the future.
What gears are even available that would fit? Also, would I be able to have my locker in the front with larger gears? What gears would y'all recommend?
4.77s are available, if rare. That's a relatively modest jump from your current 4.56s.
5.38s are ideal for 35s on a Trooper, but you would be the envy of all if you snagged a set for the front 10-bolt...long out of production and rarer than hen's teeth nowdays. I think they still have a few sets for the rear 12-bolt at Indy4x.
what are the gear availabilities for the 12-bolt modified?
THE U.S MARKET MODIFIEDS , ABOUT 0 ABOUT THE ONLY THING YOU CAN DO RELATIVELY CHEEP , IS SWAP IN A 96-97 TROOPER REAR AXLE ASSEMBLY , EVERYTHING BOLTS RIGHT UP AND THEY HAD THE ABS ON THEM SAME AS YOUR ,S YOU WILL HAVE TH=O CHANGE THE DIFF DRIVE SHAFT DRIVE FLANGE TO THE 97 STYLE, BUT YOU IMMEDIATELY PICK UP 4.55 GEARING, AND THE FRTS ARE ALL OVER THE PLACE .
It's likely more feasible (and probly same cost) to do a sas with a matching rear end swap. Getting the teeth thin enough for 5.13 or 5.38 on these little rings is kinda scary, ontop of a locker anyway lol. A sas would allow for a larger ring & pinion, which would be able to handle more abuse without having to worry about shearing teeth off the ring gear. Also a better market for lockers n such on a more 'mainstream axle'.
~psguardian
