1 - 9 of 9 Posts
I have a Rodeo V6 1995.5. I am having a problem with my fuel pump. The rodeo was running fine, one day it would not start. It started look like the fuel pump. After changing out the filter and dropping the fuel tank, I jumped the fuel pump. Started right up. Relay seems to be working and fuse is fine.
Any Ideas.
Hook a fuel pressure gauge up to your fuel rail, it should be somewhere around 40 psi. If it's not then the pump is bad.
It will not pump at all when I have is plugged in to the wiring. I can hook it up to a 6 volt battery and the car will run. I am thinking it is a wiring issue.
check you grounds. See what the voltage is at the pump plug and compare it to the voltage between the battery terminals. It should be almost the same. if not there is resistance somewhere usually the ground to body.
I used a meter to check the relay. I also check the voltage at the plug and at the battery. The voltage is the same. I am now trying to check for a ground but tracking the wires is nightmare.
Do this next. Just because the pump runs when you jump it and has no load doesn't mean it's good. If there is no voltage drop between battery and pump then ground is good. But if internals of the pump (bearings and electronics) are bad it won't give you the pressure needed to push the gas through the injectors.
1 - 9 of 9 Posts
