I have an 88 Trooper II.... Ran Out of Gas and the Problems Started...
Would not idle... Fuel filter was clogged... Replaced it got a little better... but was missing and wouldn't accept fuel... jerking around... Dropped, Flushed and cleaned gas tank, cleaned screen on fuel pump and replaced fuel filter again.. Still bumping along. Now Uneven idle from 900 to 1900 RPM's... and have to keep my foot on the pedal to keep it alive, and have to get it up to about 3000 rpms just to go with out the jerking and lunging forward... Replaced Plugs and checked the Dist cap and roter... no change... Cleaned the throttle body and mass air flow sincere... "Now" idles around 500 rpms on it own, but has a bad miss that will kill the engine. Replaced the Mass Air flow sencer... cranked and ran ok for about one minute... Bad Miss is back... now it won't idle... am I in trooper hell? can you help me!!!
