The biggest thing to remember is to mark the pinion nut. You will want to mark the nut to shaft relationship, and remove the pinion nut. Then replace the seal. When you tighten down the pinion nut, tighten it down to the mark. This should put things back where they were, and not require that you buy a new crush sleeve from Isuzu.
-Tad
