The back story:
My buddies wheel all the time & nagged at my deep seeded urges to join them, so I started the hunt for a rig. I was going to head the 'normal path' i.e. Jeep or Yota, something with a 6cyl that could be my DD & wknd crawler. While helping a co-worker with a nasty blackberry problem we got to talking about her old driveway decorations & what she should do with them, one was a no-name 2dr junker that I hauled to the local salvage yard, the other was a white (or at least it use to be) '89 Trooper LS 4cyl/5spd with NEW 29x9.50x15's & a seized 4ze1. I jokingly said she should just give it to me, AND SHE DID :!: :!: :!: (as repayment for the help with her yard) Now I have a full blown project on my hands. I am mechanically inclined & learn fast in that field but I have never taken on anything like this! I told my wheelin' buddies about my find & they said it was a good deal, both in the price & the base line rig itself as a wheeler. My heart instantly soared & my mind drew images of SAS & 8-10" of mixed susp/body lifts & huge 36"+ tires & ARBs front/rear... Then reality slowly crept in around the edges & I pulled back on the reins a bit. I have now put together a realistic build list for a 1st Gen Trooper & will chronicle the plans & progress here.
The Patient:
First things first, I need a running engine. The water pump fell off (sloppy mechanic @ a local shop) causing a massive overheat, he 'fixed it' by over tightening the pump back on. The bolt snapped & the pump fell off again, only this time to the demise of the motor. CraigsList to the rescue! Donor motor 170k on a +.020 bored rebuild, running but in need of a fresh rebuild = $100 SOLD!!!!
The Donor Heart:
The Build List:
This is in no real order & I am asking all the readers (lurkers included) to please drop your $0.02 worth on what order these should be done in after I have it running. TIA guys/gals
At this point the donor has been stripped COMPLETELY(which I found to be a very fun experience). I have taken the block, crank, pistons/rods to a local machine shop @ the referral of a friend. The shop menu consists of hot tank, magna flux & mic'ing everything to see what boring/grinding may need to be done.
Stay Tunes Folks This Ones Gonna be EPIC!
Sub Projects:
From Ghost White to White Steed - Engine
~psguardian
EDIT: had to change the name of the thread, couldn't find mine with all the other resurrection posts lol
The Patient:
The Donor Heart:
The Build List:
- 01. Plate Steele Bumpers w/D Rings front/rear, front which & receivers front/rear
02. HD Torsion Bars
03. HD Tie Rods
04. 3" Suspension lift + 1" body lift
05. Braided Brake Lines
06. 1.5" Diff Drop Brackets
07. 33x10.50x15's
08. Lockers front/rear
09. Deeper gears in diffs (stock w/4.56:1 I believe)
10. Deeper gears in T-case
11. GRB or 2nd T-case
12. Sway Bar Disconnects
13. Manual Locking Hubs
Sub Projects:
~psguardian
