1 - 3 of 3 Posts
Chasing down and replacing all the vacuum lines and a cold start problem. What is this on the driver's side fender under the fuse box with the two black fittings and the one silver one?
That one turns the smog pump on and off. It has nothing to do with a cold start problem.
Actually, the AIR pump stays on all the time and that's just a electrically controlled valve that diverts the pump's output to the silencer-muffler on the air filter housing or send the air into the ports at the exhaust valves.
Your smog pump isn't actually pumping air into the exhaust system 100% of the time.
1 - 3 of 3 Posts
