This post will be next to last in this write up.
I shall begin at the fuse block inside the cab where the three switches receive their power.
The small black device with the red wire is a circuit extender. It has provision for two fuses and can be put in any of the fuse positions. It comes with 4 fuses of various sizes. IF you put it into a currently used fuse location in your truck, the wired slot is for the new circuit and the non-wired slot is for the existing circuit. I choose the 3 amp fuse that came with the extender to handle the switches. The fuse slot I chose to power the switches requires that the key be turned to the ON position (not the accessory pos) for there to be any power. The switches have bright red lights in them and should I ever over look those glowing red lights, this prevents me from forgetting that the lights are on with the truck turned off.
You can not see the switch ground wire with the dash panel in place, but the switches are grounded to one of the screws that holds the fuse panel in place. All under-dash wires are encased in flexible loom conduit to help prevent wires rubbing on metal dash parts and shorting out. Sparks under the dash are not a good thing! This picture also shows the three switches mounted in their panel on the dash.
Now we'll move under the hood.
First, the location of the enclosure makes a very short run directly to the battery. So I drew power from the positive and ground from the negative of the battery rather than splicing into another power source or making a new ground connection.
From the battery positive terminal, (using 10 awg wire) the power first goes to a 50 Amp circuit breaker that you can almost see in the next photo.
Power in goes to the brass terminal and power out on the stainless terminal. I used household wire nuts as insulators on the terminals as I mounted the circuit breaker to the fender well with both terminals sticking straight up and so I figured they needed some protection against shorts. I made a cut-out in the wire nut so that it would slide down over the wire terminal and add another layer of protection.
From the breaker, power continues to the main power input on the enclosure, again with a wire nut insulator, again using 10 awg wire. I installed a simple stainless steel nut and bolt as a terminal into the enclosure, and the main power inside the enclosure is also 10 awg.
And out to the battery negative (for a ground) the lights and the hitch.
Let me add a bit of a precaution here. I encased any wires the carried power in wire loom. After all this, I didn't want a wire to chafe through and short out against any metal body or frame parts
The first connection made was to the battery negative terminal with 10 awg wire to provide a good ground and because I figured it was easier to attach the heavier gauge wires before the lighter gauge due to the extremely cramped space for the connections to the terminal block coming out of the enclosure.
Next I connected a power wire back to the hitch. I ran it on the inside of the frame under the truck, following the fuel and brake lines, then past the fuel tank and tied it into the Power line at the hitch.
A quick check with a test light shows all is well...
And a view from behind verifies that all the wires are hidden from view.
Time to move unto the lights..
These were relatively simple as I have had them on the truck for years and could simply reverse the wires that came with the lights, encase them in loom, and run to the enclosure for hook-up. My lights grounded through the mounting brackets. The fogs are bolted to the frame thereby providing a good ground. The driving lights are a different story. I drilled mounting holes in the plastic bumper to locate the lights and ran a ground wire from the mounts to the frame.
Again, all the wiring is hidden from view.
The color codes for these additions are:
Red - Power to hitch (10 Awg)
White- Power to Driving lights (14 Awg)
Yellow- Power to Fog Lights (14Awg)
Black- Ground (10 Awg)
Some of you may think that the 14 awg is too small for a pair of 55w lights, but its what came with the sets and has been working just fine on the truck for several years.
With all the wiring finished, it time to test...
Fog Lights:
Driving Lights:
Looking good...
and so, as the sun slowly sets in the western sky and the tools all cleaned and put away,
Its time to verify that the lights are aligned where I want them to be.
I focused the driving lights about half way between the head lights and the ground. I may change this, but I only use them at night in heavy rain and I've found that they light up the sides of the road very well this way.
I focused the Fog Lights so that the tops of the beams are between 6 and 8 inches off the ground. This gives me the best spread of light under the fog and gives me much better vision on those foggy Florida mornings.
The animation below shows the head lights, driving lights, and fog lights as I like them to be adjusted. This alignment prevents my lights from blinding another driver even if I have both sets turned on.
The End.
