Here is a little off-topic non-isuzu question.
My Fiance, today was driving up (92 Prelude) to her folks house in Northern WI, when one of her front wheels just popped off, going about 55! She notice the a problem moments before it came off since the steering wheel was shaking. She is okay and got the car off to the side of the road. A passer by helped her rebend the studs so the wheel would fit back on and removed one lug from each of the three wheels. The passer by noted, "All of the lugs on the wheels were finger tight!" So they got the wheel back on, the rims bolt holes were a bit messed up and she took it to a GoodYear place and they only had time to remove the oem nuts and move them back to the orginal wheels and screw on some other lugs on the problem wheel. They recommend a new rim (I found a used one already about 30 minutes away for 60 bucks) and new studs, but it would be fine to drive home (100miles).
Now here is the kicker. She took it into the Honda dealer about 200 miles ago for an oil change. She already checked the pay stub and it didn't mention anything about checking the brakes or rotating the tires.
So is it possible that since it has been very cold here in WI for the past week (-10 at night) that the alloy shrunk and the nuts were working their way loose over time? Mind you we live in a bi-level house with the garage that is under part of the house so it never gets below 32.
What do you think?
-Ryan
What do you think?
-Ryan
