1 - 16 of 16 Posts
tranny 1st ratio 3.77
transfer case revo gears 3.07
early nissan divorced tranfer case 2.02
dana 44 front 5.38
isuzu 12 bolt rear 5.38
3.77 x 3.07 x 2.02 x 5.38 =125.78
below stock
transfer case revo gears 2.28
axle ratio 4.30
3.77 x 2.28 x 4.30=36.96
what most people do for low gearing
axle ratio 4.56
3.77 x 3.07 x 4.56=52.77
my buddy at MPG off road says it is definately do-able.
thats my plan i am sticking to it.so i dont care if any one laughs or makes negative comments 8) recon
Negative comments1 :mrgreen:
Looks like I am at about 62 based on that formula...basically don't have the extra t-case in your top formula.
What size tire do you plan on running? I have always heard that anything over a 75:1 is overkill unless you're on serious meats.
I would go for 3.77s, 5.38s, and 3.07s first and see how much you like it before you drop the coin on an adapter.
:D i plan on running 37 x 12:50 mudder
I agree with hatfield. also if youre at about 75:1, prepare to do lots of clutchin on the big stuff.
So do you plan on modifying the stock tcase to eliminate the front out put or use your divorced case as the opposite output of the zoo one?
all i can say is that is a low range on that you can get out and walk faster then it at red line but only thing why dont you switch out the rear axel to the dana44 as well or is the Isuzu 12 bolt stronger?
Not to speak for him, but I assume he is going to use both t cases (just because he has both listed)
Sounds cool I'd like to see a mock up pic of the t case and front driveline angle. I'm actualy thinking of getting a 2x tranny and then I could use any t case 208. 205
I have a zu t case sitin aside from an auto so it's self contained.
How much is the cost you think ?? It would be sweet to have normal low and then super low.
Also in my comparisons with the isuzu 12 bolt it's as big as a ford nine inch. The sealed axle bearings are better setup than the zu 44 , I have the 44 in my amigo and ya there strong to but not as well built. But parts for the zu 12 bolt (spendy). I welded mine and ran it on the street for six years never had a problem.
Pics please lol
I've got a Dana 60 and a Dana 70, out of an old Dodge 1 ton with 5.?? gearing (don't remember if it's 5.26, or 5.77 or whatever, been too long since I looked at the tag). I've half-considered putting them in a '78 Jeep I have and making a "crawler" myself, but I really wouldn't get much use out of it. I don't get much of a kick out of 4-wheeling, and that's a big project. I should sell those diffs to someone who will get some use out of them.
That 60 front axle is gold back my way in Oregon / Washington area.
That would be a big project alwright. My amigo is set up pretty good now and I don't get the chance to off road much myself so more modifications are kinda like thoughts in space :)
But if I ever get to go out and hang with zu fella's that will make my day !!!
I looked at that art work. Looks like a pain. Another way it could be done is get a front axle with the third member on the left side and use a t case behind the existing one. If the suspension was set high then no problem. Then you could use the original front output for say a pto !!!
1 - 16 of 16 Posts
