2000 Rodeo DOHC 3.2L, ran fine when I shut it off, tried to start it 2 hours later and ran like crap and new codes. Pulled wiring harness and checked it with microscope, nothing wrong. ran compression test, no compression on passengers side, pulled valve cover and cams are not right. W.T.F.? I just went through this on the drivers side. The timing belt is new and the marks on the belt gears line up fine. The gear alignment pins are not sheared. How can the cams be off? the gears on the cams themselves are not seperate from the cams except for the preload gears. Correct?
