First, though I've been reading posts here for a while now, this is my first. This site has been incredibly informative... so thanks to everyone.
Quick background on my '98 Amigo problems: CEL went off/on for months and I never thought much about it, as tightening the gas cap seemed to do the trick. Eventually, tho, the engine started running rough... idling erratically and sometimes stalling at stoplights (just about a month before I finished paying it off, I might add). Having never done any work on cars before, following tips on this site (starting with the free ECU read from AutoZone), I was able to replace the PCV valve, replace the fuel filter, change the spark plugs, clean the EGR valve and throttle body... all to no avail.
So I finally took it to a mechanic who replaced an ignitor coil (clearing up the Cyl #4 misfire code), but still had a P0405 and P0171. They said this pointed to a vacuum leak. They even called me into the garage to listen to it whistle. However, they checked the intake gasket and accessible hoses and couldn't find any leaks. They want to open up the intake manifold, replace the gasket and look around for where the leak might be coming from, so while we wait on parts, I brought the Amigo home for the holidays.
Last night I had to take an emergency trip to the grocery. On the way home I noticed a new "rattle" under the hood that got worse at higher RPM's, but wasn't really sync'd with the engine (as a normal knocking/pinging would be). This morning, with some daylight, I checked it out and found this.
Per this diagram:
, it's pulley #2. The bracket holding this pulley on has snapped! Merry Christmas to me! Pulley #2 is now resting tightly atop the crankshaft pulley (#1). When not running, the belt is loose. But when running, somehow it's tightening up enough that I don't lose power steering and the alternator is still turning.
So my first question... anyone see this happen before? If so, what could have caused it? Second, is this pulley #2 just an idle pulley? Third, is it possible that the "whistle" we heard was the belt running over this pulley, possibly siezed, and we just didn't notice it wasn't turning? Fourth, is there any way this could have resulted in the error codes I'm getting, or is it something completely different, and I should still investigate the possible vacuum leak?
And... what's the worst damage I could do driving it? She made it about 20 miles this way last night. The shop is about 30 miles away. Should I chance driving it, or just have it towed?
Finally, regarding the diagram of pulleys, can someone ID the rest, or correct my determinations? (The Haynes manual I have isn't all that great.)
1. Crankshaft
2. ?? (just an idle pulley?)
3. Idle Tensioner
4. Alternator
5. A/C compressor
6. Power Steering pump
7. ??
7 (the other 7). The serpentine drive belt itself.
Thanks,
-Meta
Per this diagram:
1. Crankshaft
3. Idle Tensioner
4. Alternator
5. A/C compressor
7. ??
Thanks,
-Meta
