http://www.upmpg.com/tech_articles/motoroil_viscosity/
is a good article. Executive summary is a 5w-30 behaves like a 5w oil when it is cold and like a 30w oil when it is hot.
So when you changed from 10w-30 to 30w you were unlikely to see any increase in hot oil pressure.
Given your climate (much like ours in OKC) I would look at Rotella T6 which is a 5w-40 synthetic or if you are cheap look at Rotella which is a 15w-40 conventional. As hot as it is in the summer you might be able to get by with a 20w-50 in the summer - I know I ran that for a while in one of the 95 Troopers I had.
