I've lost all power to everything except the starter on my 85 trooper. I never changed anything while I was replacing the head. All I did to the battery or anything electrical was I took the negative off the battery before I started dismantling the engine. There are no dangling, loose, unconnected or broken wires anywhere. All fuses are good. At first I thought the ground was bad but now I know the ground is fine. Several people have told me that there should be a wire that runs from the battery directly to the fuse block but I haven't found one anywhere. How does the power get to the fuse box? Does anyone know what I have done?
