EGR with weber 32/36
175 Views 1 Reply 2 Participants Last post by  DSUZU
Is anyone running a functional egr system with a weber 32/36? I can't get mine functional, is it even possible?
1 - 2 of 2 Posts
Are you in an emissions inspection area? If not, "many" would say to make a block off plate. If you are, check the hose routing diagram, run everything as if it were a stock carb and make note of where the diagram calls for ported vacuum, or manifold vacuum. Dennis
1 - 2 of 2 Posts
