I need to clean the EGR valve on my Trooper, an '89 with a 2.6 engine. This is in preperation for the smog retest.
Is there a prescribed way to remove and clean the EGR? It seems to be mounted into a small plate which in turn is bolted to the intake system. The plate is just large enough for the EGR and two bolts. Is the proper method to unmount the plate with EGR attached, and go from there? That appears to be the safest.
As always, help and suggestions are appreciated.
