scoty said:
I guess I do not need a 3.5 jsut looing for something that will run the vehicle and is a direct bolt in.
I suppose that 2000-2002 Trooper with TOD is the best candidate.
Just check what is exactly your engine. It may be an early "direct injection" engine. If it is not, then everything must be the same as Trooper's.
A 2002-2003 Axiom uses a Pulse Width Modulated (PWM) Torque Converter Clutch (TCC) solenoid and clutch in the transmission, so the vehicle PCM and the transmission have to matchup. Only 2000-2002 Trooper transmissions have a PWM TCC.
Corrected : Axiom 4l30e applications
Buster28 said:
A 2001-2004 Axiom uses a Pulse Width Modulated (PWM) Torque Converter Clutch (TCC) solenoid and clutch in the transmission, so the vehicle PCM and the transmission have to matchup. Only 2000-2002 Trooper transmissions have a PWM TCC.
2004 Axiom is a totally different beast.
