So after about a year... I have been using the compressor as a carry along (Outstanding for this purpose). I finally put the tank together...dman4486 said:Ordered my 5-gal air tank, on-85psi/off-105psi pressure switch, 140psi popoff safety valve and 3/8 checkvalve 4 days ago...
IT IS ALL HERE!!!! I'll hopefully be doing an install later this week and get some pics of my new onboard air setup!!
If we meet up we are guaranteed a speeding ticket a piece lol.... Hell yea lets do it :twisted:Ruination said:Good to hear man! I should have my new beater back this weekend.. wanna meet up??
Did you make it to uwharrie this year? You should have seen my uppers before this last bit of work.... they were 3 buckets.jwood1016 said:Dang I wasn't sure you still had that bucket of bolts! Got to take her wheeling again it's a blast wheeling with that truck.
Appologies.. I was trying out something new with drive. apparently doesn't work. I'll get them moved over to Photobucket and updated prontomustanger999 said:Can't see pics. If you try to follow the url it gives this message.
"Your client does not have permission to get URL /SsMwkvY9_D0v3R9EOZESVcPU2kci7PYxvw9_uurLeyiyY0GEHxW77GKA7YTEI-hB0IO5vxxyFXYM500=w1342-h561 from this server. Forbidden That's all we know."
dman4486 said:So after about a year... I have been using the compressor as a carry along (Outstanding for this purpose). I finally put the tank together...dman4486 said:Ordered my 5-gal air tank, on-85psi/off-105psi pressure switch, 140psi popoff safety valve and 3/8 checkvalve 4 days ago...
This is the output side with a 1-to-3 distribution block, 85psi on/105 psi off switch, 1/4 inch quick connect and extra hole (plugged but thinking of a remote connection somewhere on the outside of the truck, maybe under Gas Cap?)
Input side with check valve to relieve pressure on the compressor when it isn't running and to prevent high pressure turn on.
Should be continuing installation on this project once I am back in SC in FEB.
doesn't the montero have onboard air factory?Ruination said:OK great now that you have proof of concept, order 2 of everything and install on my truck & montero please!
7 PSI compressor for the air locker doesn't count!dman4486 said:doesn't the montero have onboard air factory?Ruination said:OK great now that you have proof of concept, order 2 of everything and install on my truck & montero please!
