1 - 2 of 2 Posts
(This thread is also cross-posted at http://clubisuzu.com/viewtopic.php?f=30&t=8332 )
Good evening,
I own a Japanese 1991 Isuzu MU (sold as an Amigo here in the US.)
Elsewhere, I read someone took apart the inside of his doors to remove the side mirrors on his MU, only to discover the mirrors must be removed from the outside. I removed the mirrors on my MU using the following instructions:
Step 1: Acquire the correct tool. (See the first attachment.) I purchased this set of non-marring tools in Harbor Freight (a hardware store here in the USA). Grab the curved tool (attachment 2).
Step 2: Place a towel on the ground next to your door. (This will prevent parts from scratching if they fall onto your driveway.)
Step 3: (See attachments 3 and 4.) Use the tool on the top left corner, where the window is attached to the door. Place the tip between parts 11 and 15 on the diagram. Then pry.
Step 4: Place the tool on the top right corner. Then, pry. The cover (part 11 on the diagram) will fall to the ground. This will reveal two screws. (See attachment 5.)
Step 5: Remove the screws to remove the mirror.
For further information, check out the following website: https://www.autozone.com/repairguides/I ... 5280062c07
Godspeed!
Bill
On a related note, the mirrors on my MU are taller than they are wide. (Please see the attachment.) I assume this is because MUs from Japan were produced with different parts than those exported.
I have only been able to find replacement mirrors that are wider than they are tall, such as the following:
- https://www.1aauto.com/isuzu-pup-pickup ... 1amrp01155
- https://www.carsrus.com.au/holden-tf-ro ... or-mirrors
- https://www.ebay.com/itm/283355802482?V ... 3355802482
I cannot confirm that mirrors between Japanese and US models are interchangeable. I also cannot confirm that mirrors between MUs, Amigos, Pickups, and Rodeos are interchangeable. Also, apparently, some mirrors of this style use three screws, not two. (Please reference the following website: https://www.ebay.com/itm/302934093339?ul_noapp=true )
Does anyone have part numbers for any mirrors?
Does anyone know where I can purchase the taller mirrors that are currently installed on my MU?
Thanks!
Bill
1 - 2 of 2 Posts
