All,
Short version: I have a 2004 Isuzu Rodeo that is mechanically fine, kept in near-new condition, but will not start as the immobilizer, computer, and key are not synched. The repair guy who programs engine computers talked with Isuzu over the phone, and I'm out of luck. Even *if* I could ship the Rodeo to California, Isuzu no longer has all the tools and parts necessary to repair it. Junkyards will give me $200-$300. How do I maximize recovered value / minimize my financial loss?
I did see these posts about working around the immobilizer, with no luck so far:
The Long Story: I've been in the Isuzu community for a lot of years. I followed Randii from his original home to 4x4wire, I had a Blue 1993 Isuzu Amigo 4x4, followed by a White 2004 Rodeo 4x4 with the direct injection engine. I met a lot of friends there over the years, but was less active after the transition to planetisuzoo (although I still have my blue membership card, #11045).
I have 85k miles on the Rodeo (I motorcycle a lot). I was called up for the military so I put on new tires, changed the oil, and all was good. Three weeks and zero drips on the driveway. I drove away from AZ, and not far into the trip, my co-pilot and I heard the sometimes-loose skid plate rattling again (stripped thread). I was actually low on oil and made it 1,600 miles before it seized. The oil light never came on, and of course there is no oil pressure gauge.
When it died (rural road, middle of nowhere, 9 pm), the Check Engine Light came on first, then the oil light. I added 4 quarts just to get to the bottom of the dipstick. I found the oil all over the bottom of the Rodeo (didn't leak before) so I would guess the rear oil seal started leaking not long after I left. One half of the engine was melted and mangled, the other side was just mangled. A rebuild out of the question.
The 2004 Direct Injection engine is (a) the only interference engine Isuzu made, and (b) the rarest of the Isuzu engines. I've seen the comments about it on this board. Old 3.5L DI engines are expensive, rebuilt ones are quite expensive. While deployed overseas, I got it towed to base, then to a mechanic who went through 3 used engines to get a good one (First two had low compression and needed rebuilds, 3rd engine had 92k miles and was good). He only charged me $1900. Relevant: My battery was dead, and he was jumping it to start it, every time.
I picked up the Rodeo and drove it to base. I replaced my battery the next day, and the day after that, the Rodeo died while driving it. I was in a different town, and took it to a different mechanic. The engine computer was replaced, and couldn't be reprogrammed. Both boxes were sent to a engine computer repair shop (chip was fried; they didn't have a replacement). They put in a third computer which *did* take the programming.
The Rodeo still would not start. That's when the programmer got in touch with Isuzu and learned he would be unable to fix the conflict between the new computer, old ignition key, and old immobilizer. Isuzu's advice was to find a 2004 DI Rodeo and get the keys, engine computer, and immobilizer and swap all three with mine. Finding a computer is easy, but finding all three for a 3.5L DI engine is virtually impossible.
So here I am: A 2004 Isuzu Rodeo 4x4 Direct Injection in great condition, but for the lack of a computer code, it will not start. How do I extract maximum value out of this mechanically sound, electronically blocked vehicle? I have not given up yet (see the two links above) but am running low on hope. Also, I'm sad that I might be exiting the community as I expected to have this Rodeo for another 10 years. I had a new nice stereo, my ham radio, and it ran great. Heck, 1,600 miles with little to no oil. Now it's a $6,000 paperweight. (NADA value)
Final Thoughts: To drive home after a year of mobilization (Middle East + returned in time for Hurricane Duty) I bought a 2002 Chevy Suburban with 175k miles that needed new tires, on the spot for $3500 ($4100 total). I didn't even have to put the bike rack on back, it swallowed up all my old bags, my new gear, plus my bike rack and bicycle inside with room to spare. But I miss the Rodeo. I still have the original 2004 brochures.
Thank you for any help you can provide. I will post the outcome of contacting the two re-programmer options, above.
- Remove and/or bypass immobilizer in 2004 Rodeo? -- No resolution.[/*]
- Hey all. Newbie here with a '04 3.5DI Rodeo -- Intermittent non-start; no resolution.[/*]
- 2004 Rodeo immobilizer light blinks no crank or start -- Buster28 told Buickgsman to try two options:
(1) contacting Par-Tech about a replacement ECU/PCM and
(2) contacting EZKeyLocksmith which has now changed their link to EZCarKeys.com with a direct link to Isuzu reprogramming at this link. Buickgsman said he'd get back with results, but did not.[/*] - SOS Diagnostics has some Isuzu model ECU/ECM/PCM (name varies--in their list it's Engine Computer) in stock and also offer programming and syncing. I did not try them.[/*]
