1 - 6 of 6 Posts
Need help guys, my trany is slipping and when i put it in drive it says nuetral or low 1 etc... is this a major project or can i fix it myself? or is the trany shot? i can barly afford gas to put in it much less rebuild the trany.
Any advice would be appreciated :D
It would help if we knew what year and model you're driving. And also the search function works good on this site and would say youd to be looking at cleaning the range mode sensor.
Clean/replace the Range sensor, and change your trans fluid and filter. There's plenty of info on here about changing the fluid and filter, you just gotta hunt for it a little.
You may wanna pull the upper (smaller) pan on your trans too and see what the condition of the fluid is in there. At least thats what I was told buy the guy who rebuilt my 4L30E. Whatever you do don't have it flushed. Flushing a "neglected" 4L30E, I've heard, is a sure fire way to bring about more problems than you are having. Mind you most of this is here-say, but I wouldn't discount any of it. Good luck!
-Robert
clean your range mode sensor :)
1 - 6 of 6 Posts
